If you're real careful you can fry egg's on one. Or the tip of your finger......(Look Ma, the FBI can't print me now!
I'm not sure why I didn't get any voltage. You could be right and I might have had the MM set to AC. I tried it again a few hours later at a higher voltage and I got a voltage reading. So I twisted the knob on variac and BAM, music! (after fiddled with the speaker switch). I really love that sensation of hearing music coming out of an amp that I've been working on. thanks for your response!Excuse this basic response if this is obvious to you... Were you measuring AC or DC voltage? Remember that the diode's purpose is to rectify - to turn AC into DC so if you were measuring AC, you wouldn't get any.
Larry, I didn’t even think of this until I read your reply- I power the 400 via a buck transformer. I think I’ll tape them off like you suggested. No sense in putting the extra burden on the switch or the external transformer. Thanks for helping me think that one through! JeffYou can make the outlets unswitched by taking the extra lead and tapping it into the hot lead before the switch. OR tape off the leads and not use the outlets.
Do you do this with the tubes in or out? I agree with trying to get to a baseline thats were I am trying to get to. I was reading something about testing with the rectifier tube in but all other tubes out. Does that apply to the 400. I think it was on another tube radio site.I assume my first step would be the Hayseed Hamfest caps.maybe try it on the variac at about 60 volts. verify the bias supply is operating somewhere near 1/2 of the expected voltage, and confirm the output tube coupling caps are not leaking. Quick and dirty way of doing that is to measure the voltage across the 330k grid resistors on the output tubes. Good caps will show no voltage drop across the resistor, leaky ones will indicate voltage drop.
Leaky caps or weak bias supply will both cause excessive current in the output stage, which is what red plating really is.
I like to get some idea of basic functionality before doing a major overhaul but thats just me. Sometimes that just isn't possible but if I can do a temporary patch to get things working more or less as-found to see if it works or has some obvious major problem I do that. Not really looking for sound quality but I want to know if both channels work, the controls respond basically like they should, the tuner works, etc.
Dave, have you ever posted a drawing for Aux/Tape Monitor bleed removal, Tape Head input conversion, permanent RIAA EQ and removal of LF filter?Last up, some detail shots of the Input Selector switch as modified to permit the Tape Head Inputs to operate as high level inputs.
