audiodon
Addicted Member
The pretty one has passed its 100 hours of continuous use test with flying colors. All that's left is some time testing the outputs on a scope and that's it.
Why do I leave a unit on for a hundred continuous hours?
Once restored, I believe that these units should get so hot and no hotter.
I like to make sure that, if for some reason, the unit was left on while someone went on vacation, that the heat will not continue to build and the unit will still be on when someone returns.
I have watched my AC voltage vary more than seven volts AC over four days. The intermittent testing of the B+ and bias voltages shows me how the unit behaves and adjusts to these changes.
