Accuphase E-202
reddish75
Well-Known Member
Hi just got an Accuphase E-202 for restoration and was wondering if there was any known issues that need addressing with these, also what main reservoir caps are useable in these? Would going upto 18000uf be much of a problem?
Thanks
What diameter is the cap? I'd advise against going to 18000uf, that's nearly double the capacitance, the inrush current would be very hard on the power switch and rectifier.
Michael Percy Audio sells a 10,000µf 63V Nichicon KG Gold cap that is perfect for the E-202. 40mm x 80mm.
Edit: had the cap voltage wrong. 63V is the desired voltage of the PS cap, not 80V as I previously posted.
