across the bench: an electronic menagerie of diagnostic oddities plus photos and design analysis
highest output before distortion at 100hz into 8r resistive load was 23.5v rms (69w rms, ready to rock the house). testing a single channel since both will no doubt measure lower due to the 300va mains txf limitation.
technically this could be overcome by offloading the heater taps onto an external/secondary supple (3 taps at ~6v each) plus add a scrap 12v fan for increased air circulation inside main chassis. which would free up some extra wattage for the mains txf.
but there is only so much that should be squeezed out of an EL34, so focusing on output quality since quantity is more than sufficient should be the next consideration. hello wide wide world of signal caps...
*there are some cost effective options for the jolida 302a that rank high on this persons objectivity scale.
x4 0.22uf 600v currently (phase splitter outputs), upgrade rated for 800v
x2 0.47uf 600v currently, upgrade to 800v (400v mod will need some on/off dc measurements)
800v rating for 0.47uf unnecessary for the circuit position (overkill improves lifespan though)
*apparently i am not the only one comparing claritycap pur-?? vs jantzen
would be a good idea to establish a price per cap limit and identify a point of minimal gain vs price. an example would be 25usd/cap for a score of 10 vs +80/cap for a score of 11, definite go with the lower cost.
there is a motorola 2.1 tube amp coming up soon with EL84 config (L/R single ended, center push-pull). not sure its worth doing a clean sweep of updates and upgrades... a self inflicted diy design involving multiple 12at7 is lurking in the mental background as well. plus some r&d power supply designs for tube systems, too many ideas.
another feather weight speaker like the sansui earlier, pioneer cs-33
in good condition but need to take a look inside
whats behind door number 2 i wonder, its a rat (rat shack / radio shack)
the non-original driver does show that a standard 4 or 8 hole pattern speaker can be a drop in replacement. oddly enough the grs woofer might weigh as much as the entire speaker cabinet with tweeter. have to look around at what other options are collecting dust in the warehouse.
quick experiment with the douk a5 pro. adding a parallel power cap to see if output performance is impacted favorably. dont have an fft yet thats decent to evaluate if sinad improved or lower noise floor.
bumping up the 3300uf with an extra 3000uf
screw terminal cap rated for 3000uf 75v. the screw terminals are perfect diameter for banana terminations (dmm probes: banana to mini-clip).
no change in output wattage when adding the extra cap
even the slightly distorted peaks are unchanged. spectrum/fft analysis might show a reduced noise floor but i do not have an easy/accurate of measuring it. this is where having a quantasylum qa403 would be nice.
svc-mf+sp1632 for the kef r300 (midrange+tweeter assembly)
tangerine wave guides look ok
voice coil and spider look like there are no changes/improvements. newer driver has two stickers.
both newer drivers installed and now there is perceivable high frequency response. diameter of magnet vs diameter of cabinet hole are a little too tight hence the half moon cutouts to allow two pairs of connection wire (one cutout per wire) in and out of the cabinet, not a good design.
*apparently a few things happened with audio research co, somewhat recently
cant say that i am up to date with big name companys and there ups and downs. gentex acquiring klipsch and associated brands in its group was interesting to see. not to mention bose pulling in mcintosh and making mit a protector of the brand vs the usual vulture capitalist firms trying to make a criminal buck or two.
*cant say that i have met fred in person but did spend time at robertshaw after a few renaming/rebranding activities were transpiring. and then the end game parent company shut down the location, sent engineers to carol stream illinois and all production went to... mexico.
internal board and it has a pot that might be useful
adjusting the pot sets the over-voltage threshold of when the txf clicks to a lower voltage tap. normally around 125v steps down to 115v to protect electronics from higher than normal line/mains voltage.
