KNielsen
Well-Known Member
Off-topic:
My Aragon/Acurus inspired amp is stable!
No DC-servo or feedback cap in circuit right now when I succeed after hundreds of trail/errors, only a 1Kohm to ground after the main diff-sektionen for now.
I've added a DC-OFFSET adjustment on a breadboard earlier this day, and worked perfectly
Every time I've got a signal passing through, the oscope did to lines, like the NPN/PNP-outputs were out of fase. The position of 1N5408-diodes were the issue, and now hardwired P2P.
I still do low voltage ±32VDC, and some values are adjusted accordingly for now, but finally some testing can begin.
Best Regards
EDIT: Sooooryyyy... To early, spotted a small misbehave
but so close...
Best Regards
