Acurus L10 problem
Just make sure that the orientation of the transformer is correct, pin 1 to pin 1 on the PCB ect. It should work straight in when correctly mounted:)
Regarding the 0.1uf, they don't do much at the big e.caps. If you have 4 of them, I would place them on the button side of the PCB, close to the preamp circuit installed as bypasses at C2a/C2b and C3a/C3b
Regards
Regards
So, it's all done and up and running. All seems to be working perfectly. Sounds excellent. Would you be willing to help me through your current source Mods? I would like to plan for that next. Lemme, know. For now, I am just gonna listen. Thanks for the help so far!
Sorry can't help you there. All the basics you need to know is in post #134 https://audiokarma.org/forums/index.php?threads/acurus-l10-problem.1019429/post-17884799
If you go on to proceed, please test the CCS separately with a lab supply at about ±18VDC like the rails of your Acurus and measure the current the CCS produces before installing your version into the L10 to avoid mistakes ;)
It's easy enough once you understand the concept :)
Best regards
