ADC didn’t “perfect” the pivot block dampening until after 1978. It was then that ADC found the butyl rubber compound that really did a good job of dissipating cantilever resonance.
You will also notice that ADC made the hole between the pole ends a universal feature of later carts as ADC was able to control resonance much better.
So, what ADC found in the 25/26 and 10E, 10E MKII was that the cantilevers needed MORE damping, not less, to get the resonance more under control. The styli of the 10E MKIV and 25/26 are built virtually identically, the pivot block hardness was varied to get a change in compliance. (I’m not referring to bonded vs nude here, or straight vs tapered!) But changing the compliance did not tame the resonance.
So there is no mismatch of the 26 stylus with the MKIV body. There is only the ADDITION of more resonance control, using virtually the same stylus, in the MKIV over the previous 10Es and the 25/26.
You are making the assumption that ADC had no problems with cantilever control and resonance in the 25/26 carts. The evidence says otherwise. Or, ADC would never have needed to make changes after those carts. But change they did, because more control was needed.
If you read and compare the description of the MK4 vs the MK2, you will see this. The MK2 was constructed very similar to the 25/26.
The armatures of the 25/26 and MK2/MK4 styli are virtually identical, as are the cantilevers. So the changes in coils has more to do with other compromises than making for a mismatch of styli.
The 26 Stylus is a very good match for the MK4 in every way. Less resonance than the 25/26 carts, and still get flat response in the treble.
