Again, thanks for coming along for the ride. I hope we get people measuring the inductance of their Brick bodies and reporting back.
I'm going to make a dangerous prediction that the inductance of the 25 will turn out to be no lower than the 230XE I just acquired, so Project Futureproof Brick won't require the hard-to-get 25 body. (
HA!)
There are a couple of online vendors selling ADC-made 25 styli for as low as $18 shipped. As of this writing in 2012, that is.
UPDATE: Jul 2012: Here's a closeup of the 25 without its stylus. You can see two of the four pole pieces looking like crooked teeth inside the mouth. Notice that there's no hole in the body, just a little alcove, if you will, for the back of the cantilever to do its wiggle work in. Everything is made of sheet metal, including the pole pieces themselves.
This is the same style of "mouth" seen in the pre-Bricks and also in many early Bricks.
The later style, pre-XLM, as seen in the 10E Mk IV, looks like this 550XE:
The 550XE's pole pieces are encased in what looks like cast zinc (a guess-- it's slightly bluish), and, as with the 10E Mk IV, there's a hole let into the body. If you look at your XLM (you DO own one, don't you?), you'll see a very similar configuration, but the XLMs and later ADC cartridges line the hole with a thin-wall metal tube. This was later called CED, Controlled Electrodynamic Damping, but according to ADC (as reported by Julian Hirsch in his 10E Mk IV test), this was already happening in the 10E Mk IV, which lacks this tube. Only a guess, but the tube might have been added to produce stronger and/or more consistent eddy currents. Hirsch did note that the 10E Mk IV's high frequency resonance was underdamped.
I have one 250XE with the cast (call it CED style) mouth. My 230XE, however, has the old sheet-metal mouth. Hm?
UPDATE, Feb 2012: I just acquired a second 230XE, which has the later CED design. Hm!
EDIT: Other Bricks have since shown up with the CED mouth. It turns out that
ADC made many Bricks both ways, incorporating the innovation of the 10E Mk IV into the "lesser" Bricks (ADC called them the "X Series") as a running change. Here are the early and later versions of the Model 26 (far left) plus two X Series Bricks:
I have not seen CED mouths on models 25 or 27, nor have I found photos showing the 272, 550XE and 990XE with the earlier type mouth.
