Here is the ADC Model 26 with OEM .3x.7mil elliptical stylus. The 26 is the same as the Model 25 but with only one stylus instead of the 3 different styli included with the 25.
It has a tracking force of 0.5 to 1.25 grams with a compliance of 50. Even though its published frequency response is 10 -24k Hz +/- 2 dB, the test results show a -5dB drop at 20 Hz and a -10 dB drop at 20k Hz. The cartridge maintains the stated +/- 2dB limits from 50 Hz to 12k Hz, but definitely not the extended response of the manufacture’s specifications. I included a graph for the 10E as a comparison. As you can see, the 10E does have a 20-20k Hz frequency response. Because of its high compliance and heavy mass (8.8 grams), it is only compatible with a few low mass tone arms. In medium to heavy tone arms, there are resonance and inertia problems that cause the cartridge to mis-track and become unstable while playing warped records.
The Model 25/26 is meant to be played at less than 1 gram tracking force. Unfortunately, at those low forces, my medium mass tone arm becomes very unstable and the slightest outside movement will cause the cartridge to skip. Stability improves significantly at 1 gram, however, the stylus retracts into the stylus grip such that the bottom of the cartridge barely clears the record surface; the cartridge will actually scrape the surface if the record is warped.
Seeing the sharp drop below 80 Hz, I was curious to see how the cartridge sounds playing low frequency music. My go-to record for testing the entire frequency range is the recording of Saint-Saens Organ Symphony (San Franciso Symphony, Raffitti Pipe Organ) Philips Imported Pressing. The organ has a 32 ft. pipe that produces a 16 Hz tone (it’s more of a rumble than a tone). I don’t have a sub-woofer but I still feel the pedal notes through my system. The organ plus the other instruments covers most of the musical frequency range: each instrument should be distinct and localized even when the entire symphony is playing.
The Model 26 played the record with no distortion. The bass is strong and the higher registers (violins, piano) are clean and airy, the timpani at the end of the piece have the power and punch that I expect. However, the pedal notes are thin and there is hardly any “feel” that comes through with other cartridges.
It’s possible that the lack of low frequency punch could be due to the heavy cartridge weight and the high compliance; that combination is unique to the 26 and is not an issue with my other cartridges.
But other records sound very good. Vocals and other types of music have a very open and clean sound. There is no harshness and total lack of distortion. With the sharp drop above 12k Hz, I would expect a lack of brightness or a dull sound with orchestral bells, but there were no deficiencies in the higher frequencies. I would characterize the sound as warm although I wouldn’t say this cartridge lacks any brilliance.
