Dis-reguard what happens when playing audio, amplified signal passes these test points (TP3,TP4) which
affects the voltages at these TP's so it may look like unstable bias. Check bias as per service manual, what
you've said in the past may indicate intermittent/failing silicon, solder connections or ... dunno. Try to work
out which half (top/positive or bottom/negative) is causing the problem.
EDIT: do not expect the bias to remain constant, I did some measurement on one amp
and saw a gradual drop from 940mV down to 890mV over 45min, while not ideal I wasn't
greatly concerned, possibly due to the different Vbe of orignal/replacement TR606.
You mentioned swings upto 1.2V, this would concern me.
