The FR graph Zilch posted at #311 shows a slight up tilt as frequencies increase.
Ray's mod has them falling a bit (even though they seem to resemble some highly desirable curves).
So the goal is some where between the two?
My curves are quasi-anechoic. A flat anechoic curve yields a downward-sloping "in-room" response. Ray's curve is more representative of what we actually hear; we don't listen in an anechoic environment, typically, but outdoors with no boundaries or reflections approximates one.
Ray is suggesting that Indignias may be "voiced" to taste by varying R1. I measured the effect of different values in 1-Ohm increments between 6 and 10 Ohms here, also @ #311:
http://audiokarma.org/forums/attachment.php?attachmentid=96967&d=1214610993
Zilch, do you have a curve for unmodded Insignias?
I've never had any to measure, but Murphy, Zaph, and a couple of others who worked out mods for them have all posted "before" curves.
Has anyone here ever seen a tri-angle speaker design?
Yes, but they're not very common. It has the advantage of non-parallel walls reducing standing waves inside the box. AR "Powered Partners" come to mind.
If you look at the curved-side designs I've posted earlier in this thread, they're really triangular in the horizontal plane, truncated at the rear into trapezoids, a less extreme aesthetic having much the same benefit.
You gonna build some triangle Indignias, Tgunner? Just calculate your dimensions to approximate the 0.38 cuft design interior volume, and it'll work.... :thmbsp:
