In the simplest form, you don't need them. You drill a hole through the board at the appropriate location, poke the wire through that, and solder it to the component connection on the rear side of the board.I looked on PE, radio shack, etc....Do I need them or can I improvise some normal household item?
Solder lugs are available from electronic parts suppliers like Digikey, for example. I just happen to have a bunch in different sizes around, so I used them with screws to make the connections in that prototype. If you want to make something like that, drill holes in a copper strip and part them off.... :yes:
