skywave-rider
Slumming in Akihabara
Looks really, really nice!
Bet they sound a little bass heavy, huh?![]()
And Russellc earns Karma Indignia S/N's 25 & 26 :thmbsp:.OK, I'm done at last and they are breaking in nicely.
http://audiokarma.org/forums/showthread.php?p=2269528#post2269528
Ray's comment regarding the bass observed that you didn't have tweeters in them at the time. :tongue:
You are listening to them in freespace, without boundary reinforcement, which is how I play mine all of the time. The bass is very well-balanced, but it should be obvious from their size that these are not "Rock the house" speakers like your E'Waves behind them unless augmented with a subwoofer.
You can check the internal wiring for woofer polarity with the battery test on the input terminals. I'd suspect that if they were wrong, you'd be hearing no bass at all the way you have them set up....![]()
On the back of the cabinet, to verify that the woofer leads haven't been inadvertently inverted on one. Sounds like you don't have an issue now, though.Zilch do you mean to test polarity on the inputs of the driver itself, ( how I understood it was done) or that I can perform this test directly on the speaker wire connecting posts on the back of the box?
Indignias do not reach as low as large Advents, which are optimized for extended bass.How would those in the know compare the Indignia's bass to say the bass of the large Advent so many are E'waving with? I realize the Advent has a woofer size advantage, but just as a gauge.:scratch2:
Flat heads will work better in those two positions.... :yes:About the last adjustment I think I need to make is to possibly drill a little relief into the back lower edges of the grill, as there is interference with a couple of the woofer mounting screws. I used Black flat pan head type wood screws from PE.
There's a TCB sub simmering on the back burner....What's next?
Horizontal MTM sucks for center channel; you've got to put a MT stack in the middle for it to work worth a whit.What about an Indignia center channel, using the same tweeter but with two 6" woofs in a thin horizontal cab and the tweeter in the middle?
http://www.audiokarma.org/forums/showthread.php?t=189759
I've posted it twice, now, Russell -- use flat head screws in those two positions. Pan heads are not flat heads. Flat heads go in flush. Think sheetrock screws.Anyone else have an interference problem between the woofer mounting screws and the edge of the grill? I'm using PE flat (pan) head screws, but on the lower half of the grill, they hit the edge and hold the grill out about 1/4 of an inch or so away from the magnets. Im thinking of cutting holes in the edge to clear. I'll post a pic of the problem when I get home. Maybe if I move the locations of the screws I can get more clearance.
I s'pose it'd be possible to cut the woofer recess deeper, but anything substantial will leave a diffraction edge there; the smoother the transition, the better.
As you suggested earlier, the back side of the grille frame may be relieved at the screw head locations to provide clearance, as well.... :yes:
