YamahaFreak
Thanks, Ray and YamahaFreak! But I was expecting a cheesy, female simulated synthesized voice to provide the answer.![]()
:lmao: "Does Not Fempute"
and this is not anywhere near my "for God's sake turn it down" level.Indignias are "personal scale" speakers. If you want to rock the house with them, you'll have to mate them with a sub and highpass them as satellites.I have power options with plenty of headroom so the efficiency isn't a 'problem' here, but it has lowered my appreciation for them a little bit.
Any thoughts on what their melting point might be?
Are your Indignias running yet, Fisherdude?No single pair of speakers are perfect for every room, or every type of music. Everything is a compromise.:yes:
Are your Indignias running yet, Fisherdude?![]()
Thoughts?
I also had a chance to talk with Joe D'Appolito at the fest about his thoughts on grill screens. Very interesting.
Rear porting will work fine, and slightly larger internal volume will give you a bit more extended bass, but as you suggest, also slightly lower power handling capacity.
Our selection of cabinet size was linked to Insignias as target.
Would it be unwise to assume that the largest holes with the smallest amount of material that still keep little fingers out would be the best option?
I had always thought that some hex pattern or square pattern holes would create the least amount of difference in sound with/wihtout the grill in place, but for no other reason than being potentially the most open pattern.
