Hoping anyone with a bit more knowledge of this deck's signal path can possibly help, I have a GX-747 here that is nice and balanced when playing back tapes, everything makes sense with my test tape.
The issue I am seeing is that when set to "source" with a tone coming in there is a noticeable difference between the L and R channel (shows about 2dB on the meter), this also comes across when recording. Given that the issue is present in "source" mode am I on the right track assuming that my issue is in the Mic/Line in board (the vertical mounted one with the level pots)? I believe that is the only board that is present in both record/tape monitor and in source mode, but the schematic is a bit difficult to follow.
