Akai gxc 704d
Your description is a bit cryptic. Perhaps more detail is possible?
Did FF\REW work prior to parts replacements?
When you state "during rw the take ups oppose each other" are you saying you have tape loaded, and it does not move, or are you fooling the deck to think there is a tape loaded, then engaging RW, and you see the supply (right side) move in the opposite direction?
The belts were disintegrated when I received it, had no way to test it. After the repair The playback and ff checked ok.( Keep in mind I am a diy-er) In rw mode with tape, the tape does not move. In rw mode With no tape the left take up moves clockwise the right take up moves counter clockwise. I’m assuming I missed something during reassembly. Not sure how to “fool” tape loaded. I appreciate your time, John
Sent from my iPhone
On Oct 15, 2020, at 2:43 PM, Audiokarma Home Audio Stereo Discussion Forums <grumpy@audiokarma.org> wrote:
Lorenzenjohn, oldvinyldude replied to a thread you are watching at Audiokarma Home Audio Stereo Discussion Forums.
Akai gxc 704d
View This Thread Unread Watched Threads
Please do not reply to this email. You must visit Audiokarma Home Audio Stereo Discussion Forums to reply.
This message was sent to you because you opted to watch the thread Akai gxc 704d at Audiokarma Home Audio Stereo Discussion Forums with email notification of new replies. You will not receive any further emails about this thread until you have read the new messages.
If you no longer wish to receive these emails, you may disable emails from this thread or disable all emails.
https://audiokarma.org/forums/index.php
I don't know the exact deck, but I'm assuming it's not a "direct drive". In that case there is most likely a small rubber wheel between the spools, that kan flip on to either one. It's probably stuck on the take-up spool, for some reason.
1: find that wheel, and post a pic of it (so we may confirm)
2: carefully try to wiggle it left-and-right between the spools by hand (with the deck disconnected and the mechanics in off node)
3: look at the wheel while you push in the rewind buton. Do you see it moving?
