bjlefebvre
On the cleaning front, a record vacuum cleaning machine may be the way to go.
Late evening thought: Have you checked your RCA connections lately?
This is what I was going to say next. Clean the stylus. It could be just a tiny piece of dust stuck to it. Use a small square of Magic Erasure and lower it in that a few times.
And that is the sound when the cartridge picks up static while the record is playing. Dirty records make a crackling sound that is more random because some areas are not that dirty. Static crackling is more consistent throughout the whole record.Again I do not believe its static. Its crackling.
Do you hear it between tracks or (only or mostly) on modulated passages? If the latter: have any of your records been mistracked?Again I do not believe its static. Its crackling.
Try a correctly dampened D3 Discwasher cycle prior to play. For what ever the reason this really works well to remove the crackle. I used to have this problem with Spin Cleaned and rinsed albums I let air dry. ( micro fiber drying cloths leave lint behind I noticed ) Carbon fiber brushes did not help - only the dampened Discwasher did.
Just 4 drops of cleaner on the leading edge of brush. Spread to cover leading edge completely so it is damp. Then 3 revolutions with the leading edge down and rotate to dry side. IE Follow Discwasher instructions.Gonna try this thanks..What is a dampened D3 Cycle.....
I was having the same issue for a few days recently, i had started doing a light dusting of albums with a microfiber cloth before playing. It was a great way to build up static. Went back to a discwasher type velvet brush for pre play dusting and problem solved.
Went back and proved it out by wiping with MF and playing, heard the static. Then took the zerostat to the same album and put it right back on and played it and the static was gone.
Thanks. I'll see if I can find an affordable zerostat gun.
What I want to know is where does the dirt go when you use a discwasher brush to (clean ) records. If you don't have a way of removing the dirt like a vacuum then all you are doing is moving the dirt. As far as records go moving dirt is the opposite of removing dirt.
Discwasher and brush 2 by Mark Hardy, on FlickrYou might want to try just not wiping first.
