....touch the tone arm to find out if the receiver is plugged in properly.
Huh. I have to try that sometime. I never noticed any humming on my guitar amp, but perhaps that was because I never deliberately tried to touch a metal part on it while plugged in.No, the hum will show itself when no music is on, kind of like the guitar amp...touch any metal on that, there's the 60 cycle hum...turn the plug around, it "should" go away...if not, a grounding problem, elsewhere.
Dasher
Yup, my guitar amp has three prongs, and it's an amp for an acoustic guitar with pickup. Not sure if that makes a difference. The pickup is inside the soundboard, so it's impossible to touch. I'll try touching the tt by its metal parts and listen to any hum. I'm assuming I'll have to crank up the volume quite a bit.Off subject, but does your guitar amp have 3 promgs? If so, there wouldn't be a grounding issue, inless in the guitar or internal.
It'd show up merely on strings or pickups...
Back to tt, merely by touching tone arm, spindle or any metal piece.
Dasher
I would be curious to see: which of your cart/table combos yielded the most and least background noise?I would never allow my tap water anywhere near one of my records. Being on a well, and even with a water softener cranked up as high as possible, it still tests "hard". If any of that dried in the grooves of a record, it would ruin it. For cleaning, I use a spin-clean, distilled water, and the spin-clean cleaning solution. I dry with the spin-clean cloths and wash those separate from all the other laundry (except for the micro-fiber towels I use to wax the cars) with scent free detergent and dried on low heat without any fabric softeners. So far, results have been good. Also noticed a big noise difference depending on which turntable/cartridge I play on. Some are better than others.
Time for an elliptical upgrade.I have a Stanton I'm not happy with...it has a conical stylus...Not a lot of dynamics, pretty flat.
Not sure if you've ruled out static electricity or not but a very good test to see if your records have static is to take a styrofoam packing peanut and break it in half so you have a small piece. Put it on a table and hold your LP above it, if it's attracted to your LP, you have static.
My little destatic gun even provided one in the package as a test to prove that it removed the static charge.
After I clean the albums thoroughly. I use a micro fiber cloth to dry and then I let them air dry on a rack for a few hr's or so.
