Allison Five - Great little speakers
Sandpaper7
l purchased a pair of Allison Fives online a few months back and am completely blown away by the sound that comes out of these little boxes. I listened to a bunch of "bookshelf" speakers prior to buying the Allison Fives and wasn't satisfied with any of them. I live in Tasmania, a small island at the bottom of Australia. There's not a lot of choice down here, and what is available isn't cheap due to high freight costs.
Anyhow, I saw the A5s for sale (once again not cheap), but I was desperate. There's not much online about the 5s but everything written about Roy Allison's speakers is so positive I just bought them. I'm gonna say when they arrived I wasn't that impressed with their cosmetic appearance. They hadn't been treated well by the previous owner, but once connected up to an appropriate amp, WOW. They were crisp at the top and had unexpected bass for such a small package.
I knew straight away I was going to have to put some work into making the cabinets look as good as they sounded. There was significant water damage, but the veneer was sound and there were no chips or dents.
I got to work with some fine-grit sandpaper 120+ grit so as not to put a hole right through the veneer. It's quite thin so I was very careful, especially on the edges. Once I'd sanded the cabinets back to remove the stain and the water damage, I finished with very fine grit and coated the veneer with a water-based matt protective varnish preserving the color of the natural wood veneer.
As a final touch I re-sprayed the plastic grills with a black satin spray paint. I'm happy now that these speakers look almost as good as they sound and couldn't be happier with the finished product.
I think it's American Oak. Not entirely sure. Anyway, I guess this was one of those cases where it worked!
Nicely done. I have a high regard for Allison speakers, although I don't own a working pair (I do have one pair of Allison twos, but they're probably too far gone to be worth restoring). Be careful with the grills, though; the plastic is probably very brittle by this point (mine broke apart so easily it was pretty much impossible to reinstall them), and they are (obviously) no longer available.
No can see pretty pictures. However, those little squares with crosses should sound wonderful.
Those woofers look powerful !
Do they have a pretty heavy duty magnet assembly?
I was thinking the same thing about the grills. It's pretty cool they are still intact. Nice job on the restore! I just used some wipe on poly coat on an old pair of speakers and they came out looking nice also. Cool.looking speaker for sure.
Very true about the grills. Allison grills need to bend so they can be removed. If they became brittle they'd break very easily. My grills are still flexible but one has a 3mm hole due to the tweeter protector punching through it. Can't do much about it but maybe look out for replacement grills online.
I see all of the photos.
Great refinishing of the speakers. I like the plate protecting the woofer during the one step!
I don't know much about that brand. I'll have to watch for them.
I’d really love to see a pic of early model original Allison crossover. Seems like these rarely get posted here. I’d be interested to see if similar or different from components and arrangement of AR speakers, Roy Allison’s former company.
Here you go from my 110 above. The blue resister thing is the one that gets hot and limits power input.
Thanks for the pic - - are all of those components globbed on to the back of the tweeter magnet? Also, I'm wondering if that resistor is original - - the product lit for the 110 mentions an LC circuit, but no R.
Also attached are two pages of lit for the OP's model.
Allison 5:6*.jpg
Allison 5:6.jpg
