I've been a little lazy and not feeling well for the last couple of weeks, so speaker progress has been slowed. I fooled around and got dehydrated and had to be hospitalized for a while. I knew I was overdoing it in that hot shop, but tried drinking more to compensate. Not enough, I guess. Got disoriented and started actually hallucinating. It's a weird experience talking to people that you know are not really there! Good Mrs. GDM immediately recognized what was happening and zipped me up to the hospital where they installed a catheter on one end to catch the fluids they were pumping into the other! I hate drinking water, but I'm now forcing myself to consume as much as I can bear. Probably still not enough.
Anyway . . .
Today I installed the controls on the back of the main cabinets. In this picture, from top to bottom, the L-pads are: 1) super tweeter level; 2) mid range (horn) level; and 3) horn equalization. Remember that on this crossover I took Zilch's advice to replace one of the Altec 30923 eq resistors with an L-pad. This will allow me to control the depth of the 30923's mid range cut. Haven't tried the circuit with the L-pad in place yet, so we'll see how this works out.
The barrier strips, from top to bottom, are: 1) super tweeter output; 2) horn output; 3) 8-ohm main input. Chose to use barrier strips purely for the looks. They seem to blend best with the styling.
I had to install the horns temporarily in order to position the rear horn mount bracket, so decided while I was at it I would install one of the tops and get a look at how these are going to shape up. Since deciding to build and add the horn enclosure "top hats," these things have become outrageously tall. Once the tops are installed, they will stand 4' 1 1/2" tall!!!!!!!!!!!!! This has gotten out of hand, and I'm not sure if I like it.
Once option I've considered is discarding the bases that have the vents in them, which would lower them 6" and improve the appearances, I think. Of course, to make up for the volume loss I will need to open the cabinets into the horn enclosures and move the vents into rectangular slots on either side of the horn.
What do you guys think? Are they looking too tall, now? At the current height, when seated I'm looking directly into the mouth of the horns.
GeeDeeEmm
