Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Typically Altec used a 25 or 30 ohm wirewound potentiometer within that location for many of their crossovers from that era.
A 1 to 3 watt type will suffice for home audio.
You can test your working example by ( first disconnecting the amp and also the tweeter from the circuit, and then ) measuring the resistance of
the pot by putting the test leads onto the two outside tabs of that potentiometer.
