Todd W
Member
Hello, I am asking for help in identifying a set of Altec Lansing speakers that I have just acquired. They have 511b horns, 416a woofers and an n500e crossover box. Any help is greatly appreciated!
Specifically? A couple VOT systems, A7-500 and the A7-500W Magnificent(home version of A7-500).Is there any Altec speaker that shared these same components?
Generally? They're the basis for nearly all of the iconic loudspeaker systems as well as small format VOT systems.
The main variant among these heritage speaker loads is going to be the horn and crossover network(and the driver once bean counters got involved). There were many more speaker systems that used the same basic load with the main variant being an 800hz network and 811B horn which with it's shorter overall length fit more comfortably in reasonably sized cabinets for the home.
The N500E/800E with their fixed, stepped attenuation(preferred) would be discontinued soon after the introduction of the 416A woofer and replaced with cheaper continuously variable L-pads.
You are a wealth of knowledge. Thank you so much for taking the time. I appreciate it!Specifically? A couple VOT systems, A7-500 and the A7-500W Magnificent(home version of A7-500).
Never seen a rear panel like that internally. Looks like it kind of floats, attached at the sides to brace the horn but open to the inside at both top and bottom. Volume of cabinet is roughly 12ft/3, pretty good size.
Have you tried them yet?
BillWojo
Nice find. I love the looks of green Altecs from that era. If the components are in good working order those have potential to sound quite good as they are and even better with a simple upgrade or two, IMO.
Like others, I too am wondering about the purpose/design of the rear panel. I wonder if it was added as an afterthought to support the horn/driver, they are heavy.
Congrats on your speakers, keep us posted as you get a chance to try them out.
BillWojo
