Altec speaker purchase today
Tim Nordella
What in the heck are these? Dated 1951 and stand 47 1/2 inches tall. I did get a pair, and they sound good. Tag on the side says 4684. Look like theater speakers. Any help would be fine. Thanks
Altec 820Cs. Quite a score! Their most expensive offering for the home market at the time. Maybe even from the year I was born (1954).
http://www.lansingheritage.org/html/altec/catalogs/1954-home.htm
They where in a machine shop. Not sure but where there in 1980. He like big bands. Might be from the old movie theater that closed may years before 1980. I heard them play Metallica on them and sounded good (not into Metallica) I am more 60's and some later good stuff. They are very dirty and will require a good cleaning. There is another pair of smaller wood speakers on the wall, will check into them next week.
803's and 802's ! Sweet! Going to be well worth spending whatever it takes to get those back to great condition.
Put the latest diaphragms in the drivers, recon the woofers and rebuild the crossovers and you will be right up to date. I would coat the horns to cut out some of the coloring and change to a 1285 crossover after updating the woofers. Further improves the midrange. The question becomes is this a 16 ohm speaker system with 8 ohm woofers wired in series, or an 8 ohm system with 16 ohm woofers wired in parallel.
If the speakers are 820As they'll have the model 808 multicell horn rather than the later 811 radial horn.
An interesting feature is that in typical Altec fashion the horn loaded woofers are also bass reflex loaded, in this case through floor facing vents in the bottom of the speaker.
