Joe Stem
Member
@zebulon1 per your post i rechecked pins 8,9,10,12 just to make sure i had meter set right the 1st time
Pin 8 if measured in DC as you stated i get 10.8VDC if i checked it in AC as i did my 1st test i still get 23VAC which is correct?
Pin9 VDC 41.1 IF measured on VAC as i did in 1st test i get 85VAC
Pin10 VDC -41.9 if measured in AC on meter i get -0.0VAC
Pin12 VAC i get 3.9VAC
as for diodes can you give me some idea of the correct readings i should get... im not very familiar with diode testing... i have the correct settings on the meter i think and am getting test result im just not sure how to interpret what im seeing on the meter
