Yes, as does the HTA angle in the Denon paperSkating force decreases outer to inner: peak inner is less than peak outer.
Just out of curiosity, does the movement I'm seeing in my tonearms (in the videos) seem normal to you?
Have you tried dropping your arm in the deadwax area (non-groove)?
Thanks!
Thanks! I'm wondering if the rate at which the arms are moving toward the center seems okay with you?For an offset arm, yes, that's normal The offset and friction of the stylus on the surface/groove causes skating which pulls the stylus in toward the record center.
Doug
I tried changing the A/S setting, and it makes a HUGE difference! Just a little too little, and the arm flies into the spindle. But, I don't want the arm to have too much A/S, as that isn't good either.
Merci beaucoup!
OEM Technics 1200MkII.
SME 3009 S2 Improved on Sony 2251.
Thanks for posting this! Soundsmith says the rate should be somewhat slow, but doesn't show a video of what " somewhat slow " is.Oh, OK. I guess that seems a little fast but not unexpectedly so. I might adjust it so it's a little slower but not a lot.
I haven't really checked mine out that way in a long time because I adjust it using CD-4 records where it is more critical to have anti-skating perfect so distortion doesn't occur in either channel.
With my BIC tables, I need to have anti-skate set to about 70 -75% of tracking force, referencing the values on the scales, of course, not actual forces.
Doug
