LHorn,Dont get it near any peppers...they dont have much resistance to the tobacco virus.
Did you ever get that rabbit problem under control ?
LHorn,
Gamo makes a few. I have the Whisper. Even BB's would discourage wabbits.I still want to find a good non CO2 pellet gun to zap these rabbits
Somewhat....I had one that started a hole in the front yard again this year so I filled it in and sprayed it with the hot Thai pepper spray I made. I saw a week later while out walking that they hit the neighbor's yard next to me. All spring I would spray where they usually dig and it seemed to keep them away. I think the cats and foxes running around help..but there was still a lot of baby rabbits this year again.
If you have any remnants of leaves on your cukes it is probably worms or very small critters. If everything is gone its probably bigger target practice. I have a game cam watching over my peppers. I see on the cam the cats are regularly "marking" the fence post around my plants so that may be helping too. I may have just jinxed myself!
I still want to find a good non CO2 pellet gun to zap these rabbits with to put the fear of humans back in them...they just dont care much that you are there when you walk outside. I dont want CO2 as it wouldnt get a lot of use and I think they leak down pretty fast.![]()
There is a group of air guns that fall into what is called Break Barrel class.
Essentially, you cock the gun by pulling the barrel down, or pulling a side lever backwards, which pulls an internal piston into a cocked position, which is operated under spring pressure. When you fire it, the trigger releases this piston, causing massive forward offset of air within the pressure chamber. That displaced air forces the pellet out. Next shot, rinse and repeat.
I think its a legit subject for a gardening thread. My neighbor across the road built herself a beautiful garden. Then, an invasion of Ground Squirrels (Sage Rats) totally killed her efforts. She asked me for help, and I was all to willing to oblige.
https://www.crosman.com/custom-shop -or- www.crosman.com for their basic catalog.
go to this page, ^ custom shop link, and, choose the pistol the furthest to the right. That one is a 10 pump pneumatic, single shot.
The custom shop will build to your liking; longer barrels, higher quality barrels, custom breech, extended/removable skeletal stock to make it more like a rifle, as a shoulderable rifle.
I bought a version of this setup a couple of years ago, from Pyramid Air, which they called the BugOut kit. Ultimately, I bought an machined aluminum aftermarket breech for it, as the OE is cheap plastic, unless custom ordered, or bought aftermarket.
I use mine with a small inexpensive Winchester scope. A "Red Dot" sight would be fine, and low profile.
How do you keep the grass, etc. from encroaching?
Deer? Hopped in, hopped out?Something stepped in the garden yesterday, a day filled with rain.
Very odd pattern, single step...2 close together...then single step. With no prints coming or going and a small fence around it.
Probably aliens, with cloven hoof.
View attachment 2924561View attachment 2924562
