I'd consider the blue 235-SDE (for the 999 SE/X).
Curious, why the blue vs white?
Tucked into the notes on tVOM's Empire 235-Dxx page is the sad little insert "235-SDE only blue".Curious, why the blue vs white?
The stylus for the 999vex, the 235-vde, is rare as well but maybe a bit less rare then the 236-ZDE 1000 ZEX stylus is. It's also purple, so it matches the plastic mount of later 999-ve carts (maybe all 999-ve's have plastic mounts?, as a replacement for the 888-PE that never had a plastic mount?). But as I lamented in these back pages, the insertion tube is shorter on the 235-vde and 236-zde styli than the tube on the white and blue 235-sde styli or any of the 888 series styli or the original 999VE purple stylus, resulting in a lower volume output. It just requires turning up the receiver or preamp volume up a little, but still. I've had good luck with the aforementioned white 235 SDE stylus, as well as the white 888-TE and pink 888-VE styli. There may an inductance mismatch using the 888 styli and the white or blue 235-sde styli with the higher inductance 999-VE engine, but since the volume is stronger, it seems to work out well enough, at least for typical 60's and 70's rock music. Says me anyways.Would like to know what the best available stylus is for the 999VE
Haven't tried them myself (the PM2407DE is a generic S888E and Diamant 5579 is a générique S999VE sold on eBay from lepetitdiamant in France)... Anyone?What about 232-D7 EV PM2407DE and Diamant 5579
nearly all concerts are 'heard' via horns, then fans chase 'hifi' to emulate live sound... fill in blanks
Anyone else use a Nagaoka Stylus? The number is GD 89-401E for the 4000D, I purchased one from Rivtone awhile back but do not see any others for sale anywhere so not certain if it is still produced. Once it wears out I will most likely get a Jico Shibita or higher.
A good reason to consider a different cartridge body is when it affords you entry into a group of original styli that are both available and affordable. I often suggest getting either an 888 body or, preferably, a body from the next lineup, the one headed by the 1000ZE/X. Original made-in-USA styli for many of these models are available off the shelf.Is there a different Empire cartridge body I should consider?
I have one of those Nagaokas from RiverTone for my 4000D/I. It sounds OK but I sure wish I had a working original Empire 4000 stylus to compare it to.A good reason to consider a different cartridge body is when it affords you entry into a group of original styli that are both available and affordable. I often suggest getting either an 888 body or, preferably, a body from the next lineup, the one headed by the 1000ZE/X. Original made-in-USA styli for many of these models are available off the shelf.
Glad to hear you're having good luck with a Nagaoka replacement stylus. I don't see those too often.
... or, preferably, a body from the next lineup, the one headed by the 1000ZE/X. Original made-in-USA styli for many of these models are available off the shelf.
Anything for you Wualta. It tests at 988mH. The cantilever is thicker than any other genuine Empire I've seen in my admittedly short time. This fits your theory about it being targeted for DJs.Would be great to finally nail down the PRO-1's secret identity. Is it a recosmeticked Broadcast One (my best guess due to the DJ red cueing dot on the cantilever)? a 66/X with a black S906 stylus grip? Some Other Thing?
I didn't get any paperwork with this one, no. Will keep my eyes open though.Thanks for the measurement. That's higher than the Broadcast One and the 2000Z. Not higher in the sense of a clearly audible difference if you swapped in the BC1 stylus, but it differs enough to consider the PRO-1 as a separate model, in my opinon. Do you by any chance have any paperwork for the cartridge where Empire described what market(s) the PRO-1 was meant to serve?
