Anyone know about...Harman Kardon A700 integrated tube amplifier
kuad
Hi there!
Anyone have any knowledge of this amp?
Harman Kardon A700 integrated tube amplifier.
Grateful for any advice,
Dennis
The one that they are selling has Electro-Harmonix 7591 output tubes, a pair of rare 7199 tubes and three 12AX7 tubes.
Found some basic info from the web in my notes.
HK Award Series Integrated Amplifier
Model .................... W/ch .... Output .... Bias ......... VA/PI
A700 .................... 35w/ch ... pp7591 ... Fixed ....... 7199
A500 (A50K - kit) ... 25w/ch ... pp7355 ... Cathode ... 12ax7/12au7
A300 (A30K - kit) ... 15w/ch ... pp7408 ... Cathode ... 12ax7/12au7
The audio portion of the A700 is the same as the TA7000X receiver. My last scratch-built amp used the transformers from the latter to build a 6L6-based amplifier. Performance is very good.
Jack
I have a working A700 it could use an overhaul but is it worth the cost or should I sell it?
The last of the HK Award Series amps. I restored one many moons ago. Great iron. I also liked the fairly powerful headphone jack
About the only thing negative I would say about it is the use of 7591s.
I know 7591s sound fine but hard to find and as such, far too expensive and annoying. I dunno maybe they are easier to find these days? Any new production?
Anyways on the A700 I ended up re-pinning the output sockets to accept 6L6GCs and only having to re-work the negative bias to make them individually adjustable to suit. (it already utilizes fixed bias)
In the end was happy with the result and so was the owner
WOT
The factory cathodyne driver has insufficient headroom to drive 6L6 output tubes properly. It needs to swing about ±17V maximum for the 7591, but the lower gain 6L6 types need roughly twice that. Based on the quiescent DC voltages on the anode and cathode of the inverter, it will be operating in less linear portions of the curves as it approaches maximum drive. In addition, the driver as a whole needs to provide about twice the gain in order to maintain similar operating settings with 6L6s. HK amplifiers using the 7355 output tube (gain similar to 6L6) utilized positive feedback in the driver to accomplish this. Driver gain is greater than 300. The A700 is simply a straight pentode driver design with gain only a little above 100. I'm not saying you did a bad thing here given the situation with tube availability, but the A700 will perform better if it's fitted with 7591.
Jack
Jack
In the finished product gain seemed sufficient IMO, although truthfully I never had the chance to hear it operate on 7591 as I had none. But like I said I changed the negative bias generator completely using a different transformer that delivered over -40V to start with and added individual bias pots. It biased the 6L6GCs just fine with something just over 400v on the plates. Never had to touch the driver stage itself, although it might have been better optimized after the change. I did mess around a bit with the feedback to the driver stage IIRC trying to improve the square wave. This tube change was essentially the only solution I had at the time, but it was over 20 years ago so will have to refer to my old scribbler to confirm what else I did. Would sure like to hear another A700 with new production 7591 since they seem to be a bit more available these days. Maybe I add it once again to my list of "looking fors" lol
WOT
