I am rebuilding a TEAC V-530X tape deck from the early 80s. Mostly has Marcon caps, and though I am going to refresh the power supply, all of the caps I have pulled test good. Haven't pulled any low voltage caps yet, so can't say how they faired with age, but I won't be pulling and testing many others.
EDIT: Some of the low voltage caps are showing signs of age, as are some of the caps near heat sinks. They are 105C rated, however, which has probably helped them hold on as well as they have for so long. Will come up with a rebuild thread at some point. Only have a scat to go by, but it does have a nicely marked audio path. Bought it new the summe after my freshman year in college, and it still sounds good, but some quirky things have cropped up like no LEDs for the R channel meter (which is probably bad solder joints, but I digress...
