GD70
Lunatic Member
Some I can answer now.ok GD ... im in ... i decided i will take on the task of a full restoration but i have a few questions if you please...
1. can you please list the exact replacement parts i need ....
A. the sealer for the surrounds (brand, product?) and where to get it
B. the exact caps i need for replacement/upgrade and where to get it
C. the exact pots i need from parts express
D. a link to the fabric you use
2. i noticed that my cabs must have veneer under the paint as some de-lamination has occurred where the speakers were stored in a basement on their end....
A... can i use a paint stripper to make this paint removal easier? if so what?
B... how can the delamination be repaired?
C. is taking all the veneer off an option?
3. I read in your thread that the new pots arent wired the same as the old ones?? can you give me any hints on that ???
i would really appreciate if you could take the time to help answer these questions for me... it would be a HUGE help...![]()
Order the sealer, Larry at vintage-ar will ship it out when he returns, no worries there. I just ordered some surrounds for my AR12 woofers.
The caps are 6uf and 4uf. You'll see the printed on the original cap block in the cab. Get these from Parts Express.
Pull your pots and open them up to see their condition. Soak them in clear distiller vinegar and salt for a couple hours, wash and rinse throughly with soap and water. The dicks should have pretty smooth surfaces and the wipers should be good after the cleaning. A pencil eraser is good for burnishing the disk surface if it's good. If a bit pitted, use a dremel and small sanding disk to smooth it out. Get some dielectric grease from an auto parts store and put a thin coat on the disk, coils and pot wiper before reassembly.
You have a multi meter? If not, get on from the shack or Home Depot, they are cheap. With the meter attached to the middle and last and then right tabs, the meter reading should progress pretty smoothly from 0 to +15 and the other way 0 to -15 ohms.
Regarding the veneer, get the paint off them first and see what's there. If it's just plywood, you can epoxy the delaminates ply layers, then clamp while it cures. I use Z-Poxy, it's very thin and penetrates very well. Once epoxied, push the plywood down as flush with the front frame, wipe away the excess epoxy, cover with wax paper and clamp.
This should keep you busy for a while!
Glenn
