HamboneF18
I believe Jkents are 15 ohm. I have them in my restored 2ax.
What I read on CSP was that his are 25 ohm.
16 ohm I believe.What I read on CSP was that his are 25 ohm.
Might be too late but would get them from Jkent on Classic Speakers Page. Discounts for members here. The ones you got will work too tho as I think he's away till later in the month.Just placed an order for 4 potentiometers from vintage AR.
https://www.ebay.com/itm/193414315287?hash=item2d08643d17:g:w9gAAMXQO21RzZTf
16 ohm I believe.
That will do it I suppose. Good luck with the repair. No sense to keep the old suspension blobs on now for allignment. Maybe a 9v battery to center the VC?For my tweeter issue, I found the problem.
It’s an AR factory defect. The voice coil was mounted very crooked in the motor gap. Also, because it’s crooked, the rubbery sealant got into the voice coil gap. This dome was wedged in and glued in place!
Below, you can see how the right side in the pics (dome bottom) is not down. You can see the voice coil windings raised up in the right side of the pics; left side is flush to the face plate. NO WAY this tweeter can work properly mounted this far out of alignment, and out of the motor gap! And…glued in this way!
So my ears weren’t lying to me.
Left side flush:
Right side raised up:
