AR-2ax woofer foam
gary7
AK Subscriber
Have a set of AR 2ax woofers that need foam. Frame 11" across and cone is just at 8" across. Who has the best foam surrounds to to do these with?
Looking. Shows standard "C" rolled surround & :"Filleted" surround. Which would be the correct foam 2ax woofers?
Vintage AR can help you with that, send them a message. Also the web site classicspeakerpages.net is mostly about AR, there is a lot of expertise there.
