Aren't the tweeters the same as midrange from 2AX without the fiberglass ring? :scratch2:
Are the woofer's alnico magnets? Anybody have a picture of the driver including magnet they can post?
Hi Shacky,
The 4x tweeters are smaller than the 2ax midrange.
Attached are pics of your era 4x woofer. The dust cap is vented, and the magnet is alnico. Your specimens are original. :yes:
Other than the usual pot issue, the only other concern would be the bond between the tweeter cone edge and basket. It is often found to be detaching, but is an easy fix. If the caps are the 20uf Sprague cans, they are usually in good shape, and not likely to require replacement.
Roy
Dahlquist used a porous dust cap on the DQ-10 and DQ-20. The air leakage through the magnet gap may be very small.
I'd change the caps out even if the tweeters still play. I've found 'working' caps in ARs that measured as much as 50% off value. Caps are cheap insurance.
That was no strain on your 9090db. The A&B are wired in series unlike most other recievers.
Anyone have any thoughts on getting rid of the original rock wool and replacing it with acoustuff?
According to the lore, this is what happened; AR used rock wool because there was a FG "shortage." The period when this happened seems to correspond to the period in the 60's when industries were scrambling to find replacements for asbestos in various applications. I can't recall any time in the past 50 years when you couldn't walk into a hardware store and pick up a bundle of FG insulation anytime you needed one, but perhaps the "shortage" was for companies needing large quantities.Mine looks like rock wool too. I guess AR used the cheapest stuff they could get on these - or both ours were at a time with the yellow FG wasn't available.
