Here is my AR-XA with a newly installed Grace 707, which cost me around $90 from eBay. I had to order a Cardas DIN connector because the arm was missing the original cable. The arm was also missing the rest stanchion, so I fashioned a wood rest from Padauk.
The hardest part of the installation was drilling the hole in the top plate for the Grace. I had to buy a drill press, and a hole saw (2.125 inch) -- it took around 20 minutes to bore the hole through the steel deck, and the hole saw had to be frequently oiled to prevent overheating.
The arm base is spaced from the t-chassis by a 2" wood disk, which I bored from Padauk stock using the same hole saw for the top plate.
