Hi Pablo
Fuse is now going out straight on power-up.
I checked the unit to see if something conductive might have got caught up - there wasn't anything but I observed something else interesting.
I've attached a photo of the power supply board and a closer shot of one of the fuse-like components. When the unit is switched off but connected to mains voltage I get a voltage reading from one of the two fuse-like things of mains voltage relative to the chassis. The other measures 0V relative to chassis. (It doesn't matter which side of them you measure from). There is also a low output from the bridge of about 0.6V.
I'm not sure what these components are. But it doesn't make sense that they could be seeing mains voltage with the unit switched off. In fact I'm not sure anything on the power supply board should be seeing mains voltage.
Jon
Jon
