jn229
The other option to replacing the mat with a thicker one is to shim the cartridge in the headshell. Just about anything will work as long as it's rigid and light and can be cut to size.
Like to second this
I use the AIVS/Osage Audio brush, the VPI brush, the MoFI brushes, and the Disc Doctor's brushes all to great effect....favorites are the Osage and the MoFi's....
The most important thing is to always use as pure a water final rinse as possible after any cleaner...
The Shure gauge works very well. Yer all set!
A Spin-Clean is definitely NOT a waste of money! It is HIGHLY effective, and I don't find it at all inconvenient to use. It may or may not be as 'good' as a VPI, but it costs less than 20% of the price of the VPI, and does a dang good job. I like it so much, in fact, that I am currently in the long-term process of systematically re-cleaning my entire collection with it - several thousand discs! To say that it has transformed the quality of my collection is not an understatement.
If I had a lot of extra bread I'd probably buy a VPI too, but with my budget I'd rather spend the money on more records.
I'd suggest that flattedsixth search some of the past threads about the Spin-Clean for more opinions.
Sort of in order backwards - be careful of stylus cleaners with alcohol if you have a bonded Ortofon Stylus - it will drop the diamond in a heartbeat. Other brands are not so sensitive. Dry cleaning with Magic Eraser is always good![]()
The lightest headshells I can find are the universal ones off the 'Bay. They are around 6.7 grams with wires. SOAR wires equal the installed so it's a no gain, no loss situation.
SOAR wires are available at LPGear. They used to be like $15 or so, but have gotten more pricey now at LPGear. I'd still use them as they are that good, but it does not make me happyBUT, LPTunes has them at the original price: http://www.lptunes.com/LP-Gear-SOAR-HD4-Headshell-Lead-Wires-4-pc-Set-p/lpgsoarhd4.htm
Think I'm going to get some more
what protractors did AKers with this setup use? the overhaung or the technics baerwald? any other suggestions outside of those two?
I've used the Technics tool on an AT-PL120 with good results. kabusa.com sells them and they're cheap.
what made you decide to grab a 6.7? do/did you think that the pl120 head shell was to heavy for the 440mla cart? what was the result? much better? thanks for any reply.
- flatted
