flattedsixth
didn't find any of these light head shells on ebay after looking today. could you perhaps point me in a direction where i could buy a couple? i'll go to LPtunes to grab the SOARs, too. thanks again.
thanks for the reply, beatcomber.
yeah, i initially used a protractor off of enjoythemusic.com, and earlier this week my technics tool came in the mail, and how much of a BREEZE is this thing to use? when i slid the head shell into the piece i think i was around 53 mm. so i loosened the screws and slid the cart back a tiny notch, and i was ready to roll. very easy and inexpensive tool to get things aligned properly. i also have an ever so slight front end cock towards the head shell. this is after my adjustment to make the cart completely parallel with the grid lines on the enjoythemusic.com protractor. it's the link that says "click here for cartridge alignment tool". obviously print @ 100%. anyone else every use this?
http://www.enjoythemusic.com/freestuff.htm
I currently use a Shure M91Ed on mine and out of all the cartridges I've tried and there have been a few this is the perfect match. It also makes playing 78's easier because the current Shure 78 stylus fits on the cartridge
Yup, the older Shures are nice on this table
Something like Item # 280227012734 is usually around the 6~7 gram weight
But, the Technics shell at 5.6 is even better![]()
I'm pretty sure that the Technics tool and the enjoythemusic protractor use different calibrations to achieve correct overhang. In other words, you can't use one to verify the accuracy of the other, but either is completely effective when used independently of each other.
what did you think when you had the 440mla running in your set-up? anyways, thanks for the suggestions and i'll definitely consider this one down the line as an alternate, too.
The Shure M91ED and Audio Technica AT44mla are very different from each other. The Shure is loud and phat; the AT is crisp and precise, but may sound too bright/thin for some tastes.
My personal preference would be for the Shure w/ Jico over the AT on your table. The fact that a 78 stylus is available for the Shure just sweetens the deal.
also, i've been checking out the KAB super record grip Mk2. any legitimate value in owning one of these? i think it's like $38 on the kabusa website. thanks.
I just use a $2 hockey puck with a hole drilled in the center.
Few LPs need a weight. Some do and it usually turns up as tracking error or thin flat sound. I have a nice machined metal one I got off the 'Bay that I use occasionally. Most LPs are fine w/o it.
The M97Xe works fine on this table, BUT, you will need a phono stage that has variable resistive loading. The M97, like many Shures, wants to see something like 62~75K Ohms to get any top end. With that much load, it'll compete very well with the 440MLa. Without it, it's much darker and subdued. The other choice is to add a JICO SAS stylus to balance the top end at 47K, but then your are no longer looking at a budget cartridge
M97 tracks fine on this table, and with the brush down, it'll track any LP you throw at it. Best built into another light headshell assembly.
