How did you check or do your alignment ? Please describe your process.
since you had igd issues even before you got the ml I'd recommend you do a second take on it. something may be off.
Also, in my opinon that kind of wobble or shake is compliance related. Either the stylus suspension is shot or your tonearm bearings are not smooth enough or there is some obstruction in the movement of the arm. Remove the stylus, zero out the anti skate, zero-weight-balance the arm so it floats, and *gently* nudge it up. It should swing up then back down on its own effortlesly, perhaps oscillate a little bit before it settles. Do this in all axes - down, left and right as well. If the arm does not swing smoothly and easily in any of these directions, especially at the ends (start and end) of the record, then your bearings are too tight or not lubed enough, or the tonearm wires are obtructing the movement of the arm.
Woosh sound - are you sure the cartridge lead wires are not too close to the record ?
show us a closeup side profile when its playing.
I did the same thing, that was posted in a video above, and everything was fine with the 95E (except the IGD, which was fine for a cheap elliptical, I think I'm just too sensitive about it).
But I'll describe it, just to be sure. I leveled the turntable by putting an Ortofon bubble at around the middle of the platter, approximately where the stylus would be at the middle of a record; then I adjusted the legs of the turntable, till it became fully leveled.
I turned the counter weight on the tonearm, till the tonearm didn't react anything to lowering the cueing device (till it began floating flat). Then I set the little plastic thingy on the counter weight (don't know it's name, sorry lol) to zero. I adjusted the counter weight to sit right at around 2 grams of tracking force, and added the same amount of anti skating (2) to it.
I used the 95E for 6 months this way, and it worked flawlessly. I bought the 95ML then, and it sounded fine, but was wiggling, and jumping at some places. I thought that I did a bad adjustment, so I've put the stylus from the ML cartridge to my original, factory 95E cartridge body (which should be perfectly aligned), and it didn't help.
If the stylus suspension is shot, then I got a defective cart from factory, because it's new. I bought the TT new too, and it didn't get too much use, so the bearings are definitely not worn. I'll try out the bearing testing method tomorrow, thanks for your help.
The lead wires are not even close to the record, and this "whooshing" sound didn't happen with the 95E. But I can give you a pic tomorrow, if you need it.
