Ok see that's why pics are helpful. right off the bat I can see a few issues -
Yes the inner is off but First before you begin do not put the protractor on a soft mat. you see how it sags near the spindle ? That will throw your alignment off easily. Put it on a flat record.
Secondly paper protractors have some disadvantages and the biggest one is that you have to cut the spindle hole very very accurately otherwise all bets are off. I can see your's is not perfect. Search for the triangle cut method and use a sharp hobby knife.
Finally, and I not sure about this but experts can chime in - I see you are using a Fluance protractor. While there are $10 glass protractors available everywhere that are supposedly "universal" I am not sure if using a specific manufacturer's protractor is a good idea. They may have customized it for their tt geometry so just make sure it is a truly universal 2-point protractor.
You can find more protractors here - https://www.vinylengine.com/cartridge-alignment-protractors.shtml
also search for Conrad Hoffman's arc protractor program.
Always keep your speakers on when doing alignment (or anything when the stylus is involved). It will help ensure you are not ripping off or bumping the stylus or at least you will know if it happens.
No it was mostly for the igd issue the op is facing with the 95e , and I just noticed some problematic practices for alignment so called them out.
It seems pretty clear that your problem is not due to poor alignment. It may not be perfect, but slight offset issue is not going to cause it to jump out of the grooves.
Have you taken the various other steps that have suggested for isolating the cause?
Such as using that cartridge on a different table? Separating the table from the top of your receiver? Examining the stylus under magnification?
So, are you suggesting that his imperfect alignment is causing the stylus to jump out of the grooves?
OP, please just measure the distance from gasket to stylus tip. Please.
Unfortunately, I don't have another turntable, and I don't know anyone who has one.
Yeah I've put it next to the receiver, but it was the same.
And I still don't have a loupe, I have to get one, and I'll test it.
I measured it, and it's right around 52.0 millimeters
Agreed. The OP early on claimed to have tried different ptotractors, but now says he is using the "factory" alignment...by which he apparently means he is using the cartridge as it came in the headshell. Clearly small variances can affect IGD, but I am trying to get a handle on what is causing the gross tracking problems he describes.
If he would just do the measurement I asked for, we would know if he is at least close to correct for his TT.
Like you, don't believe he should have needed to convert to the ML to tame IGD...that issue most probably is an alignment problem.
That confirms it is in the ballpark. The ML shape is very sensitive to alignment, but not to the extent that being off by a small bit would cause the extreme issue you are having.
I can't remember anymore...did you say that it tracks fine with the elliptical stylus?
Its amazing how much zoom can be achieved on a modern cellphone camera, (or the magnifier app). This is from my iPhone -I think I should examine the stylus with a magnifying glass, and if it's visually bad, I'll try to get a replacement.
