I took it open for you. I did not take too many pictures at the time:
there are few parts I did not touch, one is headphone related things, not really nessesary and bit sceary thing to put your headphones anyway.
Other parts are polystyrene capacitors, those clear plastic caps, they are ok in my opinion.
F2661 is easy to take out so here it for you.
I did not swap all the part, I accidently ordered too low voltage value caps for those 104/100v caps on board, all 10 of them.
Also in last order I got MJE15031G / MJE15030G, they were out of stock for while.
Also, signal path cap Elna Silmic with polypropelene bypas it, my plan is to change that one out after next order. Did try to fit Panasonic ECW to replace both of them, but did not fit.
I did thought this can be considered as heretic to make so big clear out, but positive responce from you is surprising.
How I see this; these were not really presision gear from factory, they did not match resistors or capacitors together or anything, so in that sense it is better. Would Sansui used metal film resistors if they had a change? propably, least on more expensive gear. I would really like to know what kind of THD% this amp got now, but I do not know anyone who got the gear to test it or any place were I could actually had this type of work done.
For those who would like to do something like this; take your time, double check. I used 18€ solder station for this build and 5€ solder pump, it is not about the tools.
