AU-D11ii Broken RCA -phono
RTStudios
Next on my list of repairs is the broken male RCA connection on the rear. Can this be repaired or will I need a new board? Either way, what would be a good source? Thanks.
You won't find a new board. Ideally you could de-solder the double RCA from the board and install a new one, but that also will be hard to find. A more practical solution would be to install a pair of chassis mount RCA connectors to the chassis, and connect them with wire leads to the board. That won't look exactly original, but it will be functional and won't look bad. If you do this, be sure to buy the isolated type of RCA socket, and not the sort which is grounded to the chassis.
I bought this from sansui-parts-shop.com. to replace the phono input on my AU-G90X. it's not exactly the same gold plated like mine but it works. If yours has 5 legs then it should work fine.
And this one looks like it has 4 legs. Or You can look through the cinch terminal to see if there is any that look like yours. good luck!
I get an invalid certificate error when I try to go to your link. I've bought from Nies Ista, but it appears he's not answering emails, unless I've missed something.
I don't know what is going on with that web site now. I just excepted the risk and continue. I had the same issue,Nies didn't answer my e-mail. But Mathias AKA Hifi 1991 ordered the parts that I want for me. And he had no problem getting e-mail from Nies. Here is my old thread that I was asking about sansui-parts-shop.
https://www.audiokarma.org/forums/index.php?threads/sansui-parts-shop-question.885682/
