This is my latest on the bench for restoration, it has a few problems - just the normal stuff that's pretty much expected with a unit of this age.
It's new owner tried it out and found that one channel was not sounding good. The technician who had it first corrected a protection issue, but said that 'some of the Output Transistors are leaking' - whatever that means. So the owner retrieved it from the technician and brought it to me for a check over and this is what I found.
DC offset should be 0V +/-5mV
This amplifier
Left = 15mV
Right=145mV - there is an intermittent fault with this channel, tapping the main heatsink lightly causes this measurement to fly all over the place.
Bias should be 20mV +/-1mV
This amplifier
Left = 9.5mV
Right=0.1mV - this setting is also influenced by the intermittent fault as above.
I was able to adjust the above to just about acceptable readings, but only with great difficulty due to the condition of the trimmers and the intermittent fault.
Arising from the above, and of course the ubiquitous 'Black Flags', and 'Sansui Glue' the owner has requested a restore. It does have an original set of output transistors which seem to be ok, I'll be able to confirm this after I have made it safe to use.
This is the JDP version of the AU-919, so this will be number 4 of these that I have tackled, I am looking forward to getting into it.
I will be copying much of Leestereo's AU-919 Restoration choices, plus a few little tweaks of my own.
This amplifier
Left = 15mV
This amplifier
Left = 9.5mV
