So this means your components arrived? Or just preparation?And moving on...
You're coming with me!
And about 1½ hours later we have this...
Parts arrived on 23rd December.So this means your components arrived?
It certainly is.It's a lot of work to get that board out.
Yep.This accessing boards and glue removal is sometimes the bulk of the work.
Yes, primarily availability and luckily hardly any difference between them that I could see.I see you used the Nichicon UFW instead of UKW. Is this because of availability or there is not much between them?
The large capacitors were 3-legged, in other words they had an extra support pin so no need for 'Glue'.Also noticed there is no glue under/around the capacitors on this board. You would expect some under the main ones at least.
I'm pretty sure I'm going to do the MM Head Amp next, it'll be a tough one.So next up one of the bigger boards, driver or head amp or the smaller ones in the back, MC-headamp or protection?
The first one I did (my own) was by the book, no electrolytic value increases, just straightforward replacements. I have since gone through mine and applied much of the approach and changes described by Leestereo in his documented restore. I have also applied the Kuenhe modification to the MM Head Amp, and I'll be doing it to this one too.I understand you did 3-4 of the AU-919/D907 by now. Some evolution in your approach? Do you do things different now then with the first ones?
I thought that too. But in the AU-D55X I restored the main capacitors also were 3-legged and they had glue under them.The large capacitors were 3-legged, in other words they had an extra support
Yes, that one is a lot of workMM Head Amp next, it'll be a tough one
The first four Black Flags that came out of this board were once again all over the place. They should all have been 22pF and were 1.8pF, 23pF, 11pF, 5.7pF. I'll report on the others when I get to them.
Thank You SirNice restoration so far sir![]()
Regarding KSC1845, one of my preferred UK based suppliers has over 15,000 in stock.Completely unrelated, how is the supply of KSC1845's on your side of the pond?
I have been trying out the 'hairdryer method' for removing the Sansui glue, and so far it is working out very well, I don't remember who suggested it on here - but thank youwhoever it was.
Yes, and their postal costs are still very/very reasonable.Thank You Sir
Regarding KSC1845, one of my preferred UK based suppliers has over 15,000 in stock.![]()
Nice!This is the almost completed MM Head Amp, as sharp eyes may be able to see, one trimmer has yet to be replaced. (on order - eta tomorrow hopefully).
All glue has been removed, as have all Black Flags - which were a shambles when checked. Output transistors & PSU transistors have been remounted, heatsink compound refreshed. The 'Kuehne' modification has been done, thanks for your clearly documented info on this @lbcgav.
Something interesting, there were 3pF Black Flags where the schematic says they should be 6pF, but not to worry, some kind soul had added a 'Plain Jane' 3pF ceramic disk in parallel with each one on the track side.(the AU-919's I've seen definitely had 6pF Black flags in those positions).
And sharp eyes might also notice that I put raised links in place of C55 & C56 (next to green ES bipolars), as it might come in handy to hang a voltmeter or an oscilloscope probe off them.![]()
I finally got back to this after a domestic issue requiring my undivided attention.
I have now reassembled the MM Head Amp Board into the amplifier, DBT checks OK - DC offset adjustment OK too.
I just have a couple of issues I'd like to attend to around the amplifier before continuing, then I'll be onto the Protection Board and the MC Head Amp Board.
