Ronito6
There is a difference.I don't see why there would be a difference in the power switch between the different voltage models. The transformer should draw the same number of input watts regardless of input voltage. The input amperage for the 100v model would be higher than a 240v model. Most of the export models were multi voltage and the input power came through the same switch regardless of voltage setting.
If there is a difference in the power switch it's more likely a production change for cost, variability or cosmetics.
- Pete
The 230v (or 240v) version of the X1 incorporated a fuse between mains and the power switch, (or is that a voltage options switch on the back...not certain) the North American and Japanese versions did not have a fuse there nor a multi-voltage option.
I think the addition of that fuse required the need for a power switch with twice the contacts.
But Kale knows better than I, the if and the why. (I'm busting rhymes here.)
EDIT: Kale says, "That is the cover of a voltage selector for setting mains voltage
(100 - 120 - 220 - 240 V)"
Seems the Europe / 240v version is the best version.
It's happy anywhere.
