AU-X1
No, for the 33pf linked it is "Lead Spacing: 2.5 mm"
Use the second, lower link, the first wasn't ideal.
Question on the trimmers.There are three that I can't seem to find and they are 470 ohm,4.7 ohm and 2.2k ohm.What should I use in place of those?
Yup. 5k for the 4.7k is good enough.
Also back to the murata ceramic caps the 1,3 and 9 pf values were only available in the RCE series at the mouser in Texas.Should I get those or search for the RDE series elsewhere?
Patiently awaiting the mouser order for the au-x1 I cracked open a totally different can of worms the pioneer sx838 and found out I need a few parts for this one as well..
I thought silver mica was the best in pf values. Please inform me about this type of ceramic cap. Who has determined that its just as good or better?
Thanks
Thanks
See post #7 here - there are other references
http://audiokarma.org/forums/index....0-phono-stage-riaa-equalization-error.716418/
There is no direct comparison with Silver Mica here, however AK member ConradH has compared them directly, favouring Ceramic - with the important proviso that the Ceramics must be either C0G or NP0.
Enjoy.
If they haven't been compared then why would someone prefer the ceramic?
Or did I misunderstand?
No direct comparison in the link I gave, however they HAVE been compared elsewhere with Ceramic winning overall.
I am completely satisfied that Ceramics are best, with Silver Mica a good second. (paging @ConradH for confirmation)
Another consideration is the possibility of failure due to silver ion migration (aka silver mica disease), especially when installed in an amplifier circuit: "Due to this silver ion migration, silvered-mica should not be used under DC voltage stresses when combined with exposure to continuous high temperature and humidity conditions for extended periods" (The Capacitor Handbook, Cletus J. Kaiser, pg. 97).
ooo--Drop the mic.:bowdown:
I wondered why those small blue caps started showing up so prominently in other more recent restorations.
Considering the issue then: if you have mica already installed, how long is their service life if they are used in a DC circuit? How soon do you hear a difference?
I cannot imagine it being a worse issue than electrolytics in the same environment. (In which case, it would not be much of a worry for a couple or three decades.
There is some anecdotal evidence that current silver mica capacitors may be better sealed and hence able to withstand humidity and heat effects better. However, DC voltage may still be a problem; note that both Hewlett-Packard and Trimble Dayton Service Technologies specify in their respective engineering design guides that silver micas not be subject to DC voltage. Also, although no specific numbers are given, The Capacitor Handbook does state the following (pg. 97): "Silver ion migration can occur in only a few hours when silvered-mica capacitors are simultaneously exposed to DC voltage stresses, humidity, and high temperatures." Of course, YMMV, but caveat emptor!
