The emitters are 0.47 ohm and they all read .4 still soldered in place.should I remove them from the circuit and re measure or just order new ones?
If they all read the same - then that's not the problem - no need to change them.
OP's are still good and the duals don't charge up anymore they charged up a few times and I discharged them with a screw driver now after warming up for 20 min when I tried to discharge them nothing there but a faint spark new ones on order..
Tried that already All 4 are dead I ordered 4 of these to stuff the old cans.sorry I'm on my phone and can't send a link the part # is 493-8733-ND from digikey..You ordered new dual caps?
Could you please tell us brand and from where?
I didn't think a good replacement in terms of size was available.
Also...as long as you are waiting for the new caps, how about trying the duals from your other X1?
They may serve as stand-ins so your work can proceed while you wait for the delivery.
2 of those will fit right inside the original cans.Ah...I see...restuffing.
Thanks!![]()
So....What was the culprit? What prevented the voltage adjustments?
And yes the duals charged up..R40 and R41 were way out of specs and D03 read faulty unknown component on the peak tester so I put new resistors in and pulled a good one of those SV03's out of the parts unit and now both right and left F-2775 boards are dialed in![]()
I'm Fishing hard right now gotta get em while they're in but yes I'll be tinkering here and there and let ya how it's going..Freakn awesome.
I saw in one of your previous pics that you have an O scope.
You'll be doing some testing soon I assume.
I'm still working on F-2717,18 and F-2770,71 changing out the old transistors and measuring resistors and such but that's all I have left to do hopefully and then I'll need some pointers on where to probe with the oscope..Freakn awesome.
I mostly use it with a curve tracer but I bought a signal generator awhile back and plugged it into the aux on one of my amps and grounded the oscope probe and probed the speaker jacks and got a pretty good sine wave out of it but I'm not exactly sure if I was probing the right spot.This is where my experience and ability to offer advice ends, but my education begins.
(Well... continues.)
Using an O scope is a skill set I have yet to have, but I'm hoping to learn a bit here.
So as far as how to use an oscilloscope for testing or troubleshooting... its time for more knowledgeable AKers to chime in.
Connect a 8ohm dummy load across each set of speaker terminals
