What happened about the -47.5v adjustment ? - there seems to be mention that the -10v is OK but not the -47.5v ?
Note that they tell you to adjust for -47.5v because this regulator should mirror the +47.5v that the other half should output. there are 2 +47.5 // -47.5 regulators.
If you are still getting +/-63v out of these regulators they are not doing any regulating, the series pass transistors TR05, 06, 07, 08 are turned hard on.
Wondering about this too.
Some details reporting the VR# plus the TP# voltage readings will help toward our better understanding of what's happening with your F-2778 board.
As you already know your F-2778 it should measure:
VR03 measures -10.5v at TP01
VR04 measures -10.5v at TP02
VR01 measures -47.5v at TP03
VR02 measures -47.5v at TP04
If you could fill in the following it will help with our understanding.
VR03 measures ?????? at TP01
VR04 measures ?????? at TP02
VR01 measures ?????? at TP03
VR02 measures ?????? at TP04
Finally, many 2sb257 and 2sd357 have legs painted black as a bit of insulation.
Changing out all of them would call for some hFe pair matching.
It's a pain but the X1 really needs all the stability you can give it
