Audio Technica AT7V, Signet?
It's all good crap PB, thanks for the pics! The 140LC looks like the bargain, don't know if I can take the pink plastic though :no:
Jim
Manfred - "Compared to the ATN140LC used on a standard AT120 family body"
Yes, the ATN140LC stylus is much more enjoyable when mounted on the AT7V body. Same for the ATN132EP and the ATN155LC. I have been swapping the different styli between the AT7V, plus AT140LC, AT120E/T, and SLT96E bodies. To my ears, and with my setup (SL-1400, NAD 1130, Adcom GFA-545, a/d/s L8e's) the AT7V body provides a smooth and more detailed representation and a quieter background than the others. I think that it is a fine cartridge. All I have is a cheesy magnifying glass, so I can't confirm whether the ATN7V stylus is elliptical or spherical but regardless it too sounds very nice.
Cheers!
Are you stating that the ATN140LC stylus is more enjoyable than the ATN7V stylus mounted on the AT7V or the ATN140LC stylus mounted on the AT7V is more enjoyable than it is mounted on the At120?
Doing some searching after reading this post,I found this remark made on Vinyl Asylum regarding the stylus shape.
"In Reply to: RE: Looks interesting. posted by olddude55 on October 28, 2009 at 16:57:47
I wondered that myself.
I did find on a website based in Europe that the stylus is a 02X07 bi radial elliptical."
I managed to take some closeups with a Celestron 44302 digi-microscope, but can't get close enough to pin down the stylus shape.....
Nice - and looks pretty good to me: a nudie with square shank. Sides appear pretty broad, though - so I wonder whether it's actually 0.2 mil...
Greetings from Munich!
Manfred / lini
Here's a couple pics of my DL160 stylus for comparison...
...specs for the DL160 say "special elliptical, solid diamond with .07 x .14 mm rectangular cross section"
Good pic for comparision, 'cause here you can see what I meant: The sides of the diamond are significantly less wide compared to front & back on the Denon. And that's how quite a few other pretty sharp nude ellipticals look, too - e.g. on the AT130E/132EP, AT150E, ADC XLM MkIII... Hence my guess that the AT7V isn't 0.2 mil...
Manfred / lini
Does anyone know how this compares the the AT440mla and/or150mlx?
I can't answer your question, hopefully someone else here has taken the plunge that owns a 440 or 150 and will attempt a review.
LP Gear has added info to their description and to the specifications for the AT7V, including the stylus tip. They have drawn a connection to the Signet series carts and even a link pointing back to this thread....
http://www.lpgear.com/Merchant2/mer...re_Code=LG&Product_Code=AT7V&Category_Code=A3
Jim, I guess LPGear is the place to check. Plus check this link. The Group "K" and "L" styli should fit the AT7V body.
http://www.stereoneedles.com/audio-technica.html
Paul
Yikes , was checking the price for my 155LC ! So it looks like I could go with one of the K or L group. I don't need one at the moment but might be an idea to get a spare of one of the newer cheaper stylus for a rainy day .Might even be an upgrade ? :scratch2:
Would this cart be a good match with a Rega P2? Been looking for an inexpensive cart for mine, and I really liked the AT95E I had on my last TT.
Between the two carts I have at this particular price point, the AT7V and the Denon DL110, I'd say the AT7V is a tiny bit warmer while the DL110 is a tiny bit more detailed. Both use a similar stylus tip, track great with low surface noise and both work well in medium mass arms. The AT7V will have the advantage in output, MM vs HOMC. Plus, you can change stylii on the AT.
Jim
I was either debating this or one of the Denon's, so I went ahead with this one. Hopefully it will be good!
Purchase choice
I had my cartriage picked out for my Rega 2 and it was the Ortofon 2m Blue. I have recently discovered the Audio Technica AT7V and am wondering which is a "better" performer? I had, years ago, a Signet tk7e and couldn't have been any happier with it...any comparo info much appreciated :scratch2: AT $119, Ortofon $169
I'm not too good at putting into words what I hearin my head (if it makes any sense:scratch2:), but I really like my AT7V on my Rega P2. I listen to a lot of hard rock and some heavy metal, and this cart sounds great! The mids and highs sounded a lot better to me then the MC that the table had on it. Now, it might be that my system wasn't really set up for MC and thats why this MM cart sounds better to me. I do plan on getting a phono pre that has MC capabiliies soon, so maybe then I can make a better comparison. But for now, I am happy with the sound!
JimReeves nailed it
I think Jim nailed it in post 38. I also have the AT7V and DL110 and I agree with his characterization. So far I can't pick a distinct favorite. I like them both enough that I haven't bothered w/ an A/B test.
I'm spinning, jazz, classical, classic rock, and later blues in roughly equal proportions.
All I can tell you is that the AT7V is preferable to the OM20 I had before (only MM cart I'd had in a while). Never heard a 2M series cart. The OM20 had what I'd call a "forward" midrange I didn't care for in my system. The AT7V has a sweet midrange that doesn't stick out, nice warm punchy bass and smooth extended highs without sibilance or surface noise.
another vote for the AT7V as a great cart. especially for the price.
it's replaced an Ortofon X1 and it's handing the Ortofon it's @ss!
wider soundstage, cleaner sound, and fewer pops and clicks. All in all a more musical cart.
