Hey B&K guys, I've just taken a pause here to plan and do a little research etc. Currently basking in the satisfaction that comes from fixing things. (Although I won't be toasting the success just yet, not until I've got it back up in the rack. This thing has fooled me too many times before!) I bought this amp new in '83 or so, and want to put it back together in "good Nick", as they say, so I'm pondering a few things and doing some houskeeping on it.
I had been testing the amp with the MOSFETS from Newark, but I'm going to replace them with my previously sourced NOS Hitachi's at this point. Then I'll be re-doing the bias and checking DC offset for a final go at it. As for the filter caps, thanks ray, I'll check those out. "Sangamo" makes what appears to be a drop in replacement as far as size goes, and it's 16,000 uF @ 75V, which sounds 'purty darn near perfect. Since I only need two, I'm considering it. We'll see. By the way, in my scrounging I came across an outfit called "specap.com". It looks to be a good resource. "Old School" interface on line, but they do nothing but caps, including vintage and obsolete.
After about 15 min. pushing a 20kHZ signal @ around 200mV into it, I could hold my finger on the output tranny's for a second or two without discomfort, and the heat sinks weren't hot. I'll measure the temp when I do the final test regime. Interestingly, I've discovered why I didn't have any reading on the mA meter setting. Yeah, it appears that my initial test popped the 500mA fuse in the multimeter! I'm currently assessing that situation as well.
So that's where it is, and I'll post updates when there's developments.
jrh
