Tonights efforts will be all about testing trannies. Q6 on the left board might have popped for some reason, I'm going to lift a leg and test it out of circuit. The base and collector on this particular transistor are jumped together on the schematic, so I'm not confidant with an in circuit test result that shows it's bad.
Hey Greg, They are definately fragile. Compared to todays modern boards they seem cheap, but I think they were pretty standard back in the late 70's early 80's. As I mentioned before, if you work fast and fairly hot you should be good. Dwelling more than a few seconds risks lifting the traces for sure. Using a precise tip helps too. The best one I've found for these boards is a 1/16th" chisel point.How much soldering-unsoldering can these cheep B&K boards take? Solder points are so small and cheep that I wonder about a second life for these cheaply made boards.![]()
Hey Jose,How did it go JR?
I agree, it is better to test Q6 out of the circuit.
Hey ray,I removed the extra capacitance after noticing that it might have lowered the frequency response(the AK member who advised to such, might be correct). More bass,though. The ESR on the can caps are about .5 and read nearly 20,000uf.
I also reflowed the solder on the bridge rectifier board.
I was looking to install a polarized plug since a three prong plug made my preamp's volume decrease substantially.
Keep plugin, you'll get there.
Do you mind that I suggest a slightly different approach to test it?Hey Jose,
Q6 tested fine out of circuit. Output MOSFETS tested fine. I'm still going through things, but all the semi's on the Left board tested fine after the most recent event. And the pot seems to be functioning fine, even though it wouldn't adjust things when coming up on the variac after about 45 V AC.
Working through the Right board now, but I'm beginning to think I may have tweaked the pot into another current runaway by accident while I tried to get it to adjust. Maybe meter was set wrong? Not sure yet, but if the trannies all test out, I'm going to re-install and start again. There are no physical signs of damage on either board. I'll also double check the rail voltages to confirm the rectifier didn't pop.
jrh
Appreciate that jose!, Interesting thoughts all. I'm not sure I'm tracking you 100%, but I'll ponder your suggestion for a bit before trying to do the bias testing as B&K suggests. Not sure what you mean by "shorting the input". That sounds like something you would not want to do. Thanks for studying this!Do you mind that I suggest a slightly different approach to test it?
May be you try setting the value of P2 to some 50 ohms or so before powering the unit again. Have two dvm unit, one set to volts n a 20 volts scale conected to the speaker terminals (without any load) and another one across the negative rail fuse socket (fuse removed) to monitor the current on a large scale (may be 200mA or even the 10A scale to begin ). Leave he positive fuse in of course. Also, please try to power it on without applying the sine wave signal. I am starting to think that shorting the input and applying no load may be a better starting test at least to see what the bias current and DC offsets do on power up, and if you can get the current and bias to adjust in case that the dim bulb dims after the PS capacitors get charged.
A polarized plug makes sense to me ray. I may do the same when it comes to it. Batteries checked on my DMMs. We'll get it! Stay tuned.my 1 cent:
erratic, erroneous readings while setting the bias- low DMM battery.
reflowed rectifier board- full sound back.
polarized plug- amp's dead silent and case is not fully charged.
mosfet thermal runaway- variac not begun on 0.
